RCA plug stuck in subwoofer
masterofdisaster
hyderabad
On my recent trip to sweden i managed to buy the Energy take classic. It costed me little over 15k. For this cost , the sound is awesome.
But now i have a problem. Recent while i was cleaning the shelf where the subwoofer is placed , i somehow managed to break plugs from an RCA cable that are now stuck in the Left input of the Subwoofer. Any of you guys had the same problem ? Since the speakers where bought in Sweden there is no warranty in India.
Help!
The best thing to do is to take it across to a good radio/electronic repair shop and ask them to carefully remove it. Some of these people have innovative ways to solve such problems and they also have the right tools.
Try loosening the grip of the RCA plug by spraying wd40 or machine oil. Leave it for some time and try pulling it out yourself in a circular motion.
Can you take a pic and post it so that we have a better understanding...is the head still on for the pin or the head gave away and that how its stuck !!!
Or better still if you are handy with opening stuff yourself, you can remove the plate amp and the circuit board, take a small screw driver and push it inside out.
Of course a picture might make things clear for us.
Vinod
