yes. dolby does this to prevent them from being drowned in the tape noise. during playback, the reverse process occurs.
Hmm.But if that is so then whats the purpose of Dolby as an extra option?
Can you explain?Hmm.But if that is so then whats the purpose of Dolby as an extra option?
Can you explain?
When I said reverse, I meant the reverse of what happens during playback. let me illustrate - please note these values are NOT accurate, and are merely representative.
Suppose you have a loud signal at 10W power, and a faint signal at .01W power. Because of the tape medium there will always be hiss, which has say, .01W power which makes the .01W signal not very audible. When you record it with dolby encoding, the .01W signal gets boosted 100 times to 1W (but the 10W signal stays the same) .
When you listen to the Dobly recorded cassette, without enabling the dolby decoding you are listening to the faint signal at 1W and the loud signal at 10W. This is not the original signal you had, but a treble boosted one. If you like turning up the treble, then this will sound a bit better, but on recordings which already have a lot of treble, this will sound horrible (too much treble).
Now why should you enable dolby decoding on when playing back tapes?
If you are playing the tape back without turning on dolby, you are listening to the original loud signal at 10W, the boosted faint signal at 1W, and the tape noise at .01W
If you turn on Dolby, because of the volume reduction applied at the high frequency band, both the .01W noise and the 1W signal get reduced by 100, ie they become .01W for the signal, and .0001W for the noise, thus the noise has become much less than original. While this makes it duller than with dolby turned off, it should be accurate to the original input. If not, you need to get your deck checked (a small loss is acceptable. This is analog, after all)
Now, you say you like the higher treble. In that case, you should turn the dolby on, and then increase the treble on your stereo, so that the treble boost is applied uniformly to both quiet and loud signals (dolby boosts treble for only the quieter signals) so that you retain the full dynamics and impact of the recording. thus the .0001W noise will become .01W, the .01W small signal will be boosted back to 1W, So far this is the same as the undecoded Dolby recording. But now, the 10W signal will get boosted to 1000W now, giving you full impact of the treble, which would otherwise sound compressed and lacking if you had been listening to the undecoded version.
how exactly the boosting happens
Noise Reduction in Tape Recording
A million THANKS for this illustration.Why 100?
I have a small query.If .01W is boosting up 100 times when Dolby is switched on why 10W power is not boosting up by the same margin? Dolby only boosts low frequencies or what?
it boosts low power signals in the high frequency region during recording, and does the reverse process on playback. Check the curves in that link
So you mean to say that Dolby boosts up 100 times lower frequencies during recordings and reduces the same during playback in the same ratio.
Why didn't it boost the .01 power while recording? If it didn't boost it then why during playback you divide .01 power (hiss sound) by 100?
Please read my posts again. LOW POWER, HIGH FREQUENCY.
The .01W noise is already there on the tape, and does not come from the source or the equipment. Dolby is applied to the input signal while recording, but to both the signal + noise during playback, because the noise is now part of the playback signal
so it will not affect the sound where source is getting recorded(here it's tape) during time of recording.
Everything else is correct, this part is a bit unclear. Could you explain?
correct. You got it
Sometimes while recording, I saturate the tape a bit (without distorting it) to reduce the tape hiss feel during playback. This technique works when recording on NAKs but other decks cannot handle this saturation aspect. I could never succeed at this while recording on Denon, Akai and Technics decks.
as a matter of fact ruben sir i was able to achieve no hiss sound while recording on my technics deck model rs m 20 . it is a very simple deck . so i what i do is i dont record tapes on my nakamichi i record using the technics deck and play back on nakamichi . in this way even though i saturate my tape a little bit there is absolutely no hiss while playback on my nakamichi .
ps : i do not use dolby noise reduction .
