Hi all,
I have a technical question. I have D2H connection HD box V7000. The STB has a USB port and I have connected a USB pen drive to it. It gets detected and through settings I can format it to FAT32.
There’s a Recording option on the remote. When I contacted Customer care, they say there’s no recording facility. Looks like either they do not know what is really available or there’s some disconnect.
However I am able to record and play the content on the same STB thru My Library or similar option under settings.
But there’s a weird issue. The very first recording after power on is not getting authenticated. It says Authentication failure and the file is auto deleted. All subsequent recordings are fine though.
Is anyone else facing the same issue? I have already done master reset but that did not help. The behavior is the same.
I don't know what else to try. I tried using another pen drive but that did not help.
Thx
Thx
