rega amp
girishtd8262
India
Any one using rega Brio amp or rega io amp.rega dac r .your opinion about them will be highly valuable.
Rega io is 30 wattper channel is it underpowered
Rega Brio is a very good amp, have owned one in the past powering Rega rx3 it was very musical.
I upgraded from avr RXA 3050a tp rega brio.
It runs a pair of concept 20. Nevwr heard any other amp am happy with the power. Get to hear close to 30% of the volume after which it goes very loud. Cant listen evwn in independent house without disturbing neighors. Only lookimg to chamge to either spendors or harbets bookshelves. For floorstamders i might look at elicit amp
Under powered or over powered depends on so many factors and most importantly the speaker you are trying to drive
eg a high sensitivity/easy drivable speaker 15W is more than enough and a 15W to 30 W is only a 3dB increase in levels
Also amp published specs can be misleading and a 10W published spec can actually drive a speaker better than a 30W published spec...
So the more relevant question would be -which is the speaker you are trying to match it with ?
Dali lektor 6 floor standing speakers or cabasse mt31 antiqua bookshelf speakers
You may have no problem with the Dali lektor. Not sure of the cabasse as many of them used to go down to 4 ohms and while usually not an issue, difficult to say unless you hear it.
Cabasse is 8 ohm speaker.tq for the advice
