Regarding Norge Amplifier
crosstalk
Kolkata
For a room 8ft x 10ft how will the Norge 1515 perform? Or should I just go for the Norge 2060?
I would have gone for Norge 2030 for Nano speakers .But Norge 2060 is good buy if you are planning for upgrading your speakers in near future.
rgds,
Vardesh
If you have budget and don't want to keep changing your amp everytime, you should consider buying a little high end amps like Cambridge Audio, Marantz etc These are really good for music..the one I am using is a Marantz AVR..it works too well for music and movies...end of the day it is what appeals to you and your wallet...all the best.
you'd rather be better off with a sonodyne 310 at the same budget as for a 2060
i got myself a 2060 back in 2009.. it was a blind buy..
disposed it in 2010..
paired it with wharf 10.1s..
sounded very muddy
there was channel imbalance
in low volume level, all i got to hear was the highs and a very faint low.. zero mid
when volume was turned up, bass was all over the place
the 310 has a much better build, sound and finish
Hi Crosstalk,
If you have not purchased an amplifier yet, why don't you see the threads on for sale by owner, I am sure there would be something that would fit your requirements. Also other online classified websites like quikr or olx has good deals. All the best.....
