SACD Transport.. Need help
You need this to send an SACD signal to your DAC. This is the first one I have seen. You can send SACD Singhal from your SACD player via HDMI cable to this box and from here to your DAC. Your SACD player must have an HDMI output.
i have Oppo DVD, Blu-ray SACD players which have this HDMI out.
I don't know any SACD players that can output DSD digitally, as it is a copy right requirement. Some folks were using hacked sony play stations to rip SACD into DSD rips if I remeber right.
I have a esoteric SACD player, that will output normal CD's via digital out, but not
There is some fine print for this unit....
The SACD is outputed to your DAC via SPDIF ......
Most DACs SPDIF will only support 24/96 max ... and not SACD's data rate which is approx equiv to 24/192
Does your DAC provide this ? I doubt it.
You can read a detailed review in Stereophile here.
The Copyright implications for this product (despite it not interfaceable with most DACs) is also questionable
This box is meant for newer DAC which will support 24/192 on SPDIF. My older Exa Sound DAC doesn’t support it. But newer DACs will. Otherwise why they will come out with such a product which people can’t use and who is going to buy.
yes I have already read the review that’s how I know about this product. Thanks anyways.
Providing the SACD output on SPDIF is an essential part of it not being illegal. That is why they have done it, despite its limited applicatiin to most.
Output on USB would enable the SACD bitstream to be directly recorded on a computer, violating copyrights.
Hence the company had little option.
