Neo,
I can understand your long wait for the private theatre to get done, sometimes it takes a lot of time in making especially when it is a DIY, the main issue is that one should not compromise during the making, after all such rooms are made once a life time. It is good that you took the suggestion from forum member's, i always say one thing that forum is the best place to seek help because there will be host of suggestion from members without any vested interest etc.
If you will keep the room open twice daily for a few minutes the air and related issues will be automatically resolved. A dedicated entertainment room will always be great without a window. You can consider this idea for the future.
It is a great that you are considering a universal remote, this will do wonders for your room.
V.
V.
It has been quite a long wait,infact its been a saga, building my first of a kind home theatre room with acoustic treatment et al.
I was setting up my house interiors at same time and never thought of building the HT room so elaborately. Thanks to this forum as well as after talking to Aloklala, and tips from Vinay, Pandu, Manoj - I took the decision to go ahead with acoustic treatment.
I have a window that is not not going to be opened 98% of the time - probably once in a while to let some air in. Since I didn't want to remove the window and needed to keep a thin curtain, I opted for black out blinds curtain which will ensure no sunlight shadow enters the room as well as cover the window. Fortunately I could get a curtain matching wall color as well
Hope folks find this useful and can provide their comments.
My next project is to setup universal remote as well as remotely control the lights - waiting for next budget to get sanctioned
Neo
