sam9s
- Joined
- Aug 25, 2009
- Messages
- 5,239
- Points
- 113
Well, I don't think I can say much here...
But I do have a little to share in case not already known.
As you said the purpose of projector is to watch mostly movies with 2.35:1 ratio; then it does make some sense to go with a projector screen (CIH) with 2.35:1 ratio. In that case, it's recommended to use the projector with an anamorphic lens to take full advantage of 2.35:1 Bluray/HD movies.
I had recently watched a video on youtube explaining why it does make sense to use anamorphic lens instead of using 'zoom' option which results in quality loss and few other things.
I think the entire video is very interesting; but watch out from 38th minute for the explanation on projector stuff.
Home Theater Geeks 192: Aspect Ratios Explained - YouTube
technobhatt anamorphic lenses are way too expensive, the cheapest anamorphic lens is almost the same price as the projector itself!!!!. So Zooming is the only option left, however zooming on projector is optical zoom and expands the pixel, so technically there is not much of PQ loss. The main issue or drawback is that you have to manually do this this zooming every time you switch between different aspect ratios, not to forget, also device a way to mask those black bars. CIH is tough to implement with no auto zoom and memory lens feature, in comparison to CIW, where all you need is masking, no zooming required. But anyway I will see what I do when I mount the projector and experiment.
