XBMC 13 Gotham for Android alpha released .... major update ... Android Hardware Decoading and Stereoscopic 3D Rendering
XBMC
As such there may not be any ready made HTPC with XBMC but you can look out for a barebones or sometimes fully assembed PC and load XBMC if you are not into assembling yourself. It is pretty easy even for a computer novice to install XBMC and make it up and running. You can look for Foxconn or Zotac based etc., These PCs are basically targetted for HTPC purpose which you can use for music playback as well.
Here is a list of the same and I think you can get it in India as well thru ebay or any online seller.
Thanks Mani..
How do I go about in case I want to give it a shot to see if I can assemble an HTPC of my own.
1. List of Material.
2. Type and capacity of Int HDD
3. Software needed
4. The process to build.
Does this make sense?
Can I look around search and ask questions to you all for helping me, as I start building it?
With so much of data, you definitely look in to the option of having a dedicated NAS, preferably a pre built so as to keep the power footprints to minimum, plus it seems you already are planning to purchase more HDD for the same. Why not invest on a dedicated network storage and pile up all your data on it.
Any specific reason not to go for this option ??
Where is the GPU, are you going to use the inbuilt GPU with the same.???? rest all looks good. Case maybe you can opt for CM Elite series than cheapo iBall. Same with PSU, I would go with Corsair than iBall. Infact I would insist not to go for iBall or any other cheapo PSU.
Thanks for the quick reply, much appreciated.
Yes, I do have a reason for not going with the dedicated NAS option (but I would have loved it)... I do not have space to accommodate another big box like structure in my bedroom. All the A/V + system are in my bedroom, and its cramped up. Coming to power footprint, don't you think if I have a dedicated NAS I would be running it as an extra device along with my PC which currently consumes approx 135-150 watts (as per APC UPS) with XBMC on secondary video output connection.
Well, if you would suggest, what would it be, taking cost into consideration as I will have to shell out for hdd's also and prices are sky-rocketing now. A 4TB internal is somewhere near 13K and external 14K.
On a side note, if you don't mind can you share your current media storing policy (original+backups).
I will check for a better GPU. thanks for pointing that out.. As for the case, I need a flat one so i can fit it in my media center unit. I dont see a flat one with CM Elite. Any other options??
errrrr I am talking about a pre built NAS, like Synology or Ready NAS. SYnology 413j is just 7.2" Hx6.6" Wx9.0 "D and I just love the power footprint ....30W full access 7W HDD hybernated...Cost is something that synology would defy ....... but you get way you pay, its an elite series NAS and one of the best available out there. For more details check out my NAS review thread in my sig.
My media storing policy is simple. No back up as far as movies goes. For my family photos and music, I have a back up on my regular desktop (critical ones like my wife&kid and all are also backed up on DropBox). For all my office files I have a backup on GDrive ... Heavy office files like VMs are backed up on an external WD USB 3.0 1 TB drive .....
. What else is left ...
