Processor: Decided for Inter I3 3rd Generation :Any advice on which particular one should I go for.
Motherboard: Recommendation please : Should be able to decode till 7.1,all the HD formats, no 3D requirement rite now(2D hd plasma),however, should have slot so in future GPU can be added for 3D.
Should have HDMI out and Optical Out :: Reason: My current ht system, Sony DHC Fl 5d supports Optical In. Hdmi to plasma, and optical to Sony system,which outputs DTS 5.1
Hard disk: 1 TB : any recommendations ?
Ram: 4 GB: Kingston or Simtronics .Any recommendations ?
Dvd Writer: Samsung
Cabinet : ? : Not looking for a HTPC cabinet
PSU: ? A good quality PSU, since pc will be mostly on for d/l,u/l.
Display: will get a Samsung 21or 23: led monitor.
Now comes the tricky part, I will using this desktop as a HTPC also and my Plasma/Ht system, is in the adjoining room
Display & Sound: To connect the PC to Plasma(non smart) for display and to my Ht system for sound, Plan to use 20 Ft/30Ft, HDMI cable and Optical Out cable, available on Ebay for under btw Rs 1K-3K. Is anyone using such a long cable ?Is this a feasible option ?, will there will any loss in picture/sound quality by using such a long cable ? Any other recommendation?
Controlling the XBMC/Pc :: I want to use an actual remote rather than any tablet/cell. Saw some wifi Xmbc remote control on Amazon.We are looking at a distance of around 20-30 ft btw display room and the room where Desktop will be placed.Recommendations on such remotes, IR repeaters. What should be the best way of doing this.
hi Sam9s,
thanks for your inputs.
on the motherboard part,ASUS P8H61-M LX doesn't has a onboard hdmi and Optical out.
Need a motherboard with should have both, plus the provision of fixing a gpu for 3d in future.
Ram : lol, : , getting back to pc assembling post 2000 now.. been some time i guess .G.Skill RipjawsX DDR3 looks perfect.
Coming back to the remote part: still thinking over a actual remote.
Hi Baijuxavior,
This is going to be a desktop cum htpc,hence,comes the need for dvd writer, but yes, in future, can upgrade it to blue ray.. my plasma is a 2d.
How about the connectivity part.
Thoughts on 30ft connectivity for display and sound through hdmi and optical out ?
any experiences with such connectivity ?
if this works, my desktop will act as htpc also. if doesn't , then desktop remains desktop and i have to settle with another htpc :sad:
I was under the impression a GPU will be added, (hence no HDMI on board) which I would always recommend and have always recommended, that is one single component that is imp and needs to be future proof, specially if you go 3D way. Onboard GPU doesn't work (atleast for me; and I guess lots of other as well who took GT440 route).
And why would you need optical?
I can understand the urge of actual remote. Touch remote does not give that feel of watching a movie/TV ...right .... I felt that way as well initially, but once you start using it, you get the hang of it and then you don't want a physical remote.
About HDMI length, I have tested HDMI for about 10f and no different or issue. Technically I think 25ft is the limit of HDMI, also depends on the quality. I would always try to keep the HDMI length as less as possible, also would get good high quality HDMIs in this case. If the distance is too long I would probably look in to other solutions like HDMI over Ethernet adapter
1. It should definitely have the feel of a media player,
no windows feel at all, should boot directly in to my
Media Center. Though the base would ofcourse be
windows (one can opt for linux as well) but I opted to
go
for windows .....
2. Boot time as fast as possible (just like media
player), will upgraded to SSD later.
3. Quality YAMJ and polished look and feel...... with
the entire interface drooling with quality. (This was one
of my main reason to ditch media player along with HD
audio support)
4. Support for HD audio. (DTA MA and DD THD
streaming)
5. Remote for HTPC just like a conventional Media
Player
All my media is currently non 3d as i don't have a 3d display. In future, whenever, i get a 3d display, i will add appropriate GPU, but for now, its only 2d
Reason for optical is that my current ht system,Sony DHC-FL5D has optical input.
Are you refering to Full HD 1080p Up To 30 M 100FT HDMI Extender For HDTV By Cat5e/6 Cable RJ45 | eBay ?
Even without 3D, the quality of dedicated GPU cannot be matched by an build one, there can be other issues as well, which I have discussed in lots of other threads (sorry you have to search of your own). I would alwas save on the cost of a lesser priced board (without HDMI) and invest the same saved money in a GPU
so your HT does not have an HDMI ?? Then why do u need a long HDMI ...sorry I must have missed something, please re discribe your connections ...
and yes the ebay adv, that is hdmi over lan, however the quality of the product that you listed on ebay is something I would not be sure about .... but yes thats the technology to go for.
Hi Sam.. thanks for your advice on Intel G2010 Pentium Processor instead of I3, did some comparisons and this one does looks good one, plus, will its half the price
So will be opting for this one for my desktop
Still looking out for a compatible motherboard, which should have an onboard hdmi and optical out.
Need your suggestions/advice on the motherboard ? Optical out is must required,due to old receiver.
Going back to your's and Manniraj's comments, about using P4 as a htpc.
The motherboard which i have is a Via motherboard, it only has pci card slot :sad:
Can a P4- some 2ghz,used with GT440,2gigs of ram, act as a HTPC for 1080p encoding ?
Can a GT440 be used on my existing motherboard which is only has a pci slot ?
Looking out for your valuable suggestions on the above..
Hi Sam,
I am looking at HTPC primarily playing XBMC using probably openelec. However, I need a slim cabinet as it will be in the living room and USB3.0 support. Can you give suggestions?
Man your optical, requirement is tough, even on a bit expensive boards optical is tough to find. I could not find any 1155 ASUS board under 10K with optical ( if any fellow member can suggested, that would be good)
I was only able to find
1. Intel Intel DH77EB price around 7K
2. Gigabyte. GA-H77N-WIFI price around 8-9K
both of them also have HDMI.
COming to P4, which mobo model you have. (also is it a slot 1 loading P4?) GT440 is PCIe so I dont think its gonna work.
Thanks for the suggestion Sam, Intel one looks like a good option.
Motherboard which Iam using right now is from MSI actualy, Model# .P4MAM2-V
Hi Sam,
