Bro OpenELEC can run on any hardware, there is nothing wrong with your specs as well. I however would try to keep it more smaller with mini itx form factor. Why are you not considering Gigabyte E350N
I have built an HTPC based on AMD AM1.
enclosing some pics
Used the HTPC was impressed with the sound and video will install another 2TB HDD
Somak
congrats somak, the cabinet looks to me like zebronicsis it? your cable management may require some improvement. I am guessing on the left of your TV that is the saraswati "Bina" .
I recently bought an Antec ISK600 Mini ITX Case and need to buy a suitable power supply.
I'm a little rusty with computer builds and have no experience with mini-ITX. Please chip in with what power supply will be suitable without breaking the bank. Thanks!
Do you want to go with the DC PSU power supply or the conventional AC PSU ?
better use DC one if your CPU power requirement is not above 50-60 Watts... You get a really power efficient & silent CPU for Multimedia & average Home PC usage.
Antec ISK600 takes any regular standard ATX power supply ..... whats the confusion for you? Any corsair standard ATX power supply will do depending on what your config is ...
I was looking for specific model recommendations which suit a HTPC, silent, VFM et al. Also, I guess I was doubtful if a ATX size PSU would even fit well in this little case. I admit I have not done enough homework here.
@Sam,
In one of your posts I noticed that you are using the Aeon Nox skin.
One thing I am not able to find here on Aeon Nox is the button palette when on the Music screen. Is there some setting hidden somewhere that displays this ?
By button palette I mean the following button set
Stop | Pause | Play | Skip | etc..
When playing audio music the absence of this is highly :annoyed::annoyed:
Would be great if anyone can give me pointers on how to get this to show up on the Music screen.
I think normally during the playback if you hover the mouse or press any key you get those buttons. That's how it shows up in mine during the movie playback.
Does not happen for Music Audio playback with the Aeon Nox set.
Yes Video it does pop up on top.
With other skins this is not a problem, the button palette is visible. It is only with Aeon Nox where it does not appear.
