Samsung c32650 with airtel dth issue help
manoj4986
Dear all,
I have bought c32650 along with which a airtel stb came free.This connects to tv with A/V cable and it runs in tv in a/v mode only.
In tv mode i have selected the region and then clicked channels -> autostore but none of channels are getting saved.I am not able to use samsung remote for changing channels and in a/v mode cannot use channel manager.
I can use only airtel remote in a/v mode for changing channels.
Can anyone tell me how to solve this problem?
Dear all,
I wonder what your problem is. Everything seem to be working as expected.
If you have connected regular cable to your TV, then use your TV remote to change A/V mode to T/V mode and from there on you will be able to store and use channel manager.
If nothing except airtel is connected to the TV, nothing will appear in the TV mode. :rolleyes:
If you are using only Airtel DTH, the channel manager of the TV is pretty much useless.
Let me understand it this way do you want to use a single remote to control the TV and STB ? Is that what you are looking for ? :rolleyes:
If you have a RF out port in yr STB and a RF Tuner in Port in TV connect them by RF cable.... if i have understood the issue correctly, this should be the solution.
