samsung hdtv 54 inch projection tv
bimalved
Banned
Banned
mumbai
Hi Members ,
I have some problem with my projection tv , its been over 2 years i have not used the tv , today when i started its not turning on ... there is a blank screen ..
what do u recommend to do i stay in mumbai ... wld there be problem with the lamps .. pls suggest a good technician or should i send it to company .
rgds
Mate, is it under warranty? I would recommend you call the samsung tech guys as they will let you know the problem and the damage as well(repair cost)...
hi mate
no its not under warranty, its been 4 yrs , tv was doing well , until i stopped using it ..
i guess thats the only option i guess .
thanks
