Samsung LA40C550 LCD Owners thread!
Hi Guys,
Did anybody used dlna feature in this model. I successfully hooked up this TV to my wireless router and can play files from my laptop to tv directly...but i am not able to play subtitles along the movie. Any ideas,any other software working for this case.....i tired mezzmo,playon,tversity..!!?..any other things i left out..?
---Firmware update Problem----
There is a new firmware available Ver. 1011.1 released on 28th Jan 2011.
After downloading this update file and installing into USB, there are 2 folders that is created in USB. However, as per the users guide, this should create only one folder in order to run on TV. (This is clearly mentioned as Caution!).
Note sure why this is happening.. did anyone of you face this probelm? Infact, the previous update did not create 2 folders and the update was successful.
i also bought this LCD tv few days ago. i have a question i hope you guys can help me.
i would like to buy a 500gb HDD to play lots of Bluray movies with a file size of more than 10gb to my Samsung Series 5 LA40C550.
my question is...
what is the maximum file size that this LCD TV can read? because i am going to play a movie with a file size more than 10gb?
and what will be the format of my HDD? NTFS or FAT32?
but the thing is you can only transfer max of 4gb to a FAT32 HDD?
i hope you guys could help me on this since we have the same LCD model.
i bought my Samsung Series 5 LA40C550 LCD one week ago. :)
but i have few questions.
what is the maximum file size that this LCD tv can read?
and someone said here that a 500 gb HDD can be attached to this LCD TV. because i would like to play bluray movies with a size of 10gb and above from my 500gb HDD.
what will be the format of my HDD NTFS or FAT32? what format of HDD will be compatible for this TV?
i am asking this questions because it was not mentioned above. so it will be clear to all having this LCD TV.
hope you guys can help us.
i purchased this tv for 49k in chennai .
it was working fine since i purchase 2 months back , there is no complaints other than subtitles issue with few videos.
and i would like to know how much does the wireless adapter cost .
and if i purchased it can i use internet using that
I am having exact same problem for LA46C550. Were you manage to update the firmware? I am really not sure which folder to use. I tried with putting files from subfolder to root of USB (one folder at a time) and still nothing worked.
It can play everything.almost. I have not come across a bluray rip it did not play, even the 20GB Tron and avatar movies.
Sent from my MB525 using Tapatalk
Could someone tell me the optimal settings for my Samsung LA40C550 to watch HD Relay using Hathway HD Set-top box.... Like Brightness, contrast, sharpness, tone etc...
Thanks!!
Thanks!!
Optimal Picture quality setting for TV watching -
In Picture Mode - Movie
Just changed the below settings-
Reduced Colour from 50 to 40
Reduced Brightness from 45 to 35
Changed Tint from G50/R50 to G49/R51
does anybody using this model have connected your computer using DVI/VGA.... If so, can we have a look and feel of computer screen on the TV.
In my picture options my setting for
Screenfit is greyed off
How come you have this
Have i got to do something else to get it back
maybe the Tv is set for store demo mode nd needs to be cleared
I have only my TATA sky box connected nothing else
that too not via HDMI but component cable
Same for the
Tint
and
HDMI
pls let me know
I have used most of yr settings as detailed.
Purchased the LA40C530 @ Rs 48000/-
calibration setting i am using ( found on net)
TV (FreeView, Sky etc.):
* Picture Mode: Standard
* Backlight: 3
* Contrast: 100
* Brightness: 43
* Sharpness: 0
* Color: 37
* Tint: G55/R45
* Eco: Enable No Signal Power Off
Advanced Settings:
* Black Tone: Off
* Dynamic Contrast: Off
* Shadow Detail: -2
* Gamma: 0
* RGB Only: Off
* Colour Space: Native
* White Balance: See Below
* Flesh tone: 0
* Edge Enhancement: On
Picture Options:
* Color Tone: Warm 1
* Size: Screen Fit
* Digital Noise Filter: Off
* MPEG Noise filter: Off
* HDMI Black Level: Normal (0-255)
* Auto Protection Time: 2 hours
Grayscale:
* Red Offset: 23
* Green Offset: 21
* Blue Offset: 15
* Red Gain: 45
* Green Gain: 20
* Blue Gain: 21
