samsung plasma anti image retention
akshay
bangalore
hey guys...
i hav a samsung ps50c550 50" plasma tv
i was just wondering if there is any software or a video which white washes or removes and image retention
i came across pixelshifter and plasmadvdsaver and stuff...
can some1 point me to a gud solution and some tips???
thankz
You can run the burn-in slides now and then. It is brand new. Avoid using fullscreen mode till 1000% hours. Keep all settings 50%.
what burn in slides???
can u be specific pl???
and can some1 tell me the optimum settings for samsung ps50c550???
thanks
and can any1 tell me how long and how often i should use the scrolling option???
will too much scrolling also affect my tv???
Search for and download the plasma_break-in_v120.1.zip. This is a folder with 120 solid color slides from light to dark and red to violet. The frames are numbered - so all you have to do is unzip this into a USB stick or Hard drive and then open it as images and then slidescreen play for say - half hour to one hour.
That will get rid of any TIR. I do it once every few weeks at standard image settings.
