samsung scm 6700 tonearm mechanism?
Oc2
Scotland
tonearm does not start turntable. removed turntable and noticed L shaped pin loose. Picture attached. Does pin go into hole in plastic part next to it?
Does the motor move when you lift the tonearm? Does the belt have proper tension? If the belt has become loose, the platter may not move.
