[Settings] Samsung ln46c610 46"
sago
here
I'm facing my tv, on the right side about 5 feet away is the window. What settings would be great for this situation? I know nothing about setting changes please help me out
Hang a heavy drape on the Window.
Srini, just to tickle you, I am not putting a smiley with my reply. :):)
lol
which settings are best? i was told that your suppose to have your own settings and not default settings
If you want to get the best out of the TV continue to use the same setting as you mentioned " You are facing it" ;):rolleyes: ...
haha you got me good
I guess it doesn't matter...was just told that depending on your room you should have your settings changed.
Anyways...one more question. I have a hd pvr reciever and xbox, i want to view both is that possible? just like the picture below
pip
First, ensure that your Blu-ray player has the color space output set to YCbCr 4:4:4 via HDMI and that xvYCC is turned off.
Mode: Movie
Backlight: 4
Contrast: 88
Brightness: 48
Sharpness: 0
Color: 60
Tint: G50/R50
Eco Solution:
Energy Saving: Off
Eco Sensor: Off
No Signal Power Off: 15 minutes
Advanced Settings:
Black Tone: Off
Dynamic Contrast: Off
Shadow Detail: 0
Gamma: 0
Expert Pattern: Off
RGB Only Mode: Off
Color Space: Custom
10 Point White Balance: Off
Flesh Tone: 0
Edge Enhancement: Off
xvYCC: Off
Picture Options:
Color Tone: Warm 2
Digital Noise Filter: Off
MPEG Noise Filter: Off
Auto Motion Plus: Off
Auto Protect Time: 2 hours
