You may want to check mede8er media players. It's very good in handling 3d and has many additional features too..
Mede8er - The greatest show on earth
You can ship to India..$190 + shipping cost...that is for med600x3d without any internal drive space in it.
Well, I own a 3D TV, so would like to invest in something which is capable enough to handle upscaling algos, as well as 3D stuff.
what would you recommend?
I do not know any motherboard that supports HDMI 1.4a with onboard graphics powerful enough to drive stereoscopic 3D. You would need to get a motherboard supporting at least current dual core processors along with pcie x16 slot where you can plug in a gpu LIKE nvidia gt 440 OR Raedon HD 6540.
But this path will not allow you to reuse your current PC as RAM and PSU both might require to be upgraded along with the rest of the components anyway.
I also agree with lake1988 that media players are evolving day by day yet for flexibility of upgrade HTPC will be the way to go.
Which 3D are you talking about, 3D ISO frame Sequential, is a different ball game all together. SBS, TB are just plain files any media player/HTPC including 350N will play easily.
For 3D ISO get any decent Dual Core like C2D or any AMD varient with compatible mobo .... or if you want to have something better (for may be used as casual processing as well) ....get a first/second gen i3, with compatible mobo, add a GT440/GT630 (both same 440 is discontinued I guess) and you are all set for full 3D ISO.
Remember you will also have to invest in a decent S/W player Total Media theatre 5+ as far as I am concerned is the best when it comes to 3D playback on windows, even better than Power DVD
When it comes to playing blu rays the PC and BDP should give out identical output technically since no upscaling is coming into picture. The only thing on PC that you would need to bother is getting the softwares in right tandem.
However when it comes to upscaling from non-HD to HD content there you may find a difference. All entry level BDPs and TVs do some sort of upscaling on the other and the quality of upscaling varies depending on the video chip on board. Even for PCs there are custom software upscaling methods like DXVA, madVR which eats CPU power and delivers good upscaling. Hence the cost of some of the highly expensive BDPs out there in the market which apart from the video chip also has good quality DAC chip built for improving Audio CD playback but that is a different topic altogether.
I would say if given the option of budget sub 20K, I would always go with PC with the right softwares. For 20K+ budget go for separate BDP and for less than 10K budget there is limited option but still BDP should be the way to go unless you have a existing PC to do a BD Drive upgrade.
But if you have variety of ripped contents formats then BDP (even costly ones) might not support all of them gracefully including future formats (unless there is a manufacturer made firmware upgrade to intentionally allow compatibility) in which case a PC or a media player will again b your saviour.
My BD player can play from 2 TB hdd, can play from network file shares wirelessly (automatically detects any device connected to the wifi and shows shared folders) and can play youtube etc.
What i miss terribly is there is no cool interface like xbmc where movies are nicely organized with metadata downloaded from the internet. If there was a BD player that does that, i'd buy it today.
Here is an Intel based configuration , will provide an AMD based one later
You need to add RAM (4GB DDR3), PSU, cabinet, HDD on top of this with the exception of RAM rest you have to evaluate for reuse vs buy
Motherboard - Rs 4600 (supports upto Core i7, has USB 3, pcie 3.0 support, can drive 2D 1080p video with onboard HDMI supported by the CPU in case you want to add GPU later on for 3D)
Gigabyte GA-B75M-D3H Motherboard - Gigabyte : Flipkart.com
CPU Option 1 - Rs 3600 (low - med settings of madVR)
Intel 2.9 GHz LGA 1155 G2020 Processor - Intel : Flipkart.com
CPU Option 2 - Rs 6600 (high madVR settings)
Intel i3 3220 - Intel : Flipkart.com
Grapahics Card - Rs 4600
ZOTAC NVIDIA GT 630 Zone Edition 2 GB DDR3 Graphics Card - ZOTAC : Flipkart.com
so total anticipated damage would be 24K.
But i hope it would be future proof for atleast next five or more years to come.
Add PSU and Cabinet and Remote (MC Remote)![]()
Unless you enter into an upgrade race with resolution (4K, 8K, 16K . . .) exactly as Flat Panel manufacturers would like you to think![]()
I have the LG BD 670Which BD player you own sash?
