"Show only Participated Threads", as in Tapatalk
Santy
Bengaluru
Hi guys
How many of you came back to the forum to check if there are any developments only in the threads you participated. Or you wanted to check them out first, before reading other new posts?
When we click 'Unread Posts' since last visit, it currently shows all unread posts, with an icon to differentiate if we had participated in it.
In the same lines, if there is a filter on the top, "show only participated" it would be very useful. I find this quite handy on Tapatalk.
What do you guys say? Is there any other option already existing?
If not, Mods could consider this.
I guess its a simple tweak in the coding.
There is a workaround for this. You'll need to enable an option in settings which marks all the threads you posted in as your subscribed thread. Once you enable that, all you need to do is bookmark this link http://www.hifivision.com/subscription.php?do=viewsubscription&folderid=all and it'll show you all the threads you are following.
There is one huge problem with this though. It only works for thread you posted in AFTER enabling this option. So, whatever threads you posted in earlier wont be showing up in this list until you either make a post there again Or manually subscribe to the thread/s using "Thread Tools" option at the top of first post in any thread. Which is going to be a pita when you've already posted in 100s of threads here.
Another option, a slightly more complicated one, is to go to advanced search, type out your userid in the top right box. It should show "find posts by user" as default below it. And simply hit enter (or click the "search now" button). That'll give you all the threads you posted in too. Now there might be a way to make this specific search into a link so that you don't need to go through all the steps everytime you want to find these threads but I have no idea how to get that link.
Anyways, You can eitehr use that everytime you want to look for these threads or use this search option to find these threads and start manually subscribing to all 437 threads (huge pita i know) you already posted in so that once done, all you need to do is check your subscribed threads.
