thanks rahuln.
Did you audition any other Onkyo system like 3400 along with LS3100? If so, how does it compare? I am talking about the sound quality and not any surround effect which will not be present in the LS3100. Though I think that the LS3100 is not VFM, I am keeping it as an option due to lack of alternatives.
I am suprised that the AVR did not handle DD audio properly, AVR should work with any speaker setup 2.0/2.1/3.1/5.1
Anyways, I think if I go with the AVR way - I will go with the Denon 1312 at 15K, sounds good VFM. Can someone suggest goos speakers with the 1312 within a max budget of 15K. I would like the speakers to have some bass as I do not intend to purchase a subwoofer in the near future.
Has anyone heard the Swans M50W? Seems to have good reviews.
So far these are my options, not in any order of preference -
Can someone help with deciding the speakers please?
The plan is to audition the Onkyo LS3100 and the edfier S730 ( thanks a lot to FM chaitu.genius for that).
If both are good enough for me, I will go with Edifier S730 as I will save lot of $$.
If Onkyo LS3100 is much better than Edifer S730, then I plan to go to Pro-fx and try out some bookshelves with denon 1312.If I am spending 30K, I should try out other options as well..right?
The LG sound bar is the last option as I can't have an audition and there are no 'real' users who can provide feedback.
And if I get too frustrated with all these, I might buy a PC speaker like the Logitech Z623 and connect it to the TV through the headphone socket
~Aadi
thanks rahuln.
- Onkyo LS3100 - price 30K.
- LG NB3520A sound bar - 19K
- Edifier S730 - 19K
- Swans M50W - 16.5K
- Denon 1312 + ?? speakers = 30K.
~Aadi
