blackscorpio
Looking for a small amp for bedroom setup
I decided on Fosi BT20A, based on the reviews & recommendations online.
I was also considering Lepai 2020TI.
Just wanted is there anything better before I pull the trigger.
Budget : max $100 lower the better.
Used is fine.
size does matter, anything similar to bt20a.
BT is good to have but for better sound I can sacrifice bluetooth.
one input is enough, planning to use it with TV & CCA but I am okay to change the cables manually.
planning to get it from USA.
any recommendations.
Used is fine.
