Anil kumar
I was really inspired by the thread at diy audio.com on Seas Thors. Thor was designed by D'Appolito based on Augspurger's work. Thor uses very expensive Seas drivers like W18E001 woofers and T25CF002 "MILLENNIUM" tweeter mounted in a D'Appolito configuration. These drivers are beyond my budget & reach. So here in this experiment, the idea here is to build a similar TL based on the budget minded drivers. Here i am using locally procured driverse & xover bought from Sreekanth sometimeback. On testing these mid bass, the sound qualty was much better than a Vifa (exceptional mid range quality) so thanks to sreekanth for excellent quality drivers.
But this design may not sound like Thors, but definately sounds much better than a 30K bass reflex speaker. Dave of Planet 10 has custom design on Fat & a Short THOR equivalent for VIFA P17 drivers.
In this modified design there is a solid brace behind the driver ( Mid-woofer magnets should fit tightly to notch) this transfer & distribute the energy from the driver to the back of the cabinet & the other one runs parallel with the baffle notch. Brace needs to be filled with random holes. It has 4" long & 3 " dia port at the back. I am building this for a cousin of mine here in Bengaluru. I started off with the project yesterday, here are some progress pictures.
From the drawing board
Front baffle is doubled by sandwitching two 19mm MDF boards
MY DIY PAGE
MY DIY PAGE
