kapvin
8" = 20cm so a wave length of 40cm =~ 855hz.half space= with the speaker on 1 reflective surface. typically the floor.
The wavelengths of sound frequencies audible to the human ear (20 Hz–20 kHz) are thus between approximately 17 m and 17 mm, respectively.
( is the above correct ?? )
so for a front baffle of 8 inches wide like my current Merlin TSM speaker, we will expect a 6 dB boost for all freq with wavelength above 100 mm ??
i guess this will start from 3000 Hz and above...
and BSC is a negative compensation / negative reinforcement right ??
above is simplistic but for me i am looking for broad answers ( unless notable exceptions ) so i can tighten my gut feel.
Kindly validate
thanks !
mpw
your speakers are almost definitely compensated. from what I have heard. If I were to hazard a guess I would say about 4.5dB. you could ask on the merlin boards.
BSC is mostly negative by attenuating the frequencies above the BSC frequency.
