Sony Bravia HX850 Reviews
More pictures.. :)
More pictures.. :)
My picture setting:-
Scene GENERAL
Backlight 3
Picture 90
Brightness 30
Color 50
Hue O
ColorTemp WARM2
Sharpness 50
Noise Red OFF
MPEG Noise OFF
Dot Noise OFF
Reality Crea OFF
Video Area OFF
Resolution OFF
Noise Filt OFF
Smooth Grad OFF
Motionflow CLEAR
Cinema Mode AUTO 1
Black Corrector OFF
Adv. Contrast LOW
Gamma DEFAULT
LED Dynamic STANDARD
Auto Light Limiter OFF
Clear White OFF
Live Color LOW
White Balance R GAIN: 0
G GAIN: 0
B GAIN: 0
R BIAS: 0
G BIAS: 0
B BIAS: 0
Detail Enhancer OFF
Egde Enhancer OFF
Skin Naturalizer OFF
I/P Conversion QUALITY
Eco OFF
Wide Mode FULL
Auto Wide OFF
4:3 Default OFF
Auto Display Area OFF
Display Area FULL PIXEL
Screen Position N/A
Vertical Size N/A
Any suggestions for better picture let me know. I used THX Optimizer. I am confused whether to switch on noise reduction, mpeg noise reduction, dot noise reduction, reality creation, video area detection, smooth gradation, black corrector, auto light limiter, clear white, digital enhancer, edge enhancer and skin naturalizer. Should i switch on auto wide, 4:3 default and auto display area.
Thank you.
Setting for watching d2h hd
Target Inputs: Current
Picture Mode: Custom
Backlight: 2
Picture:90
Max Brightness: 45
Color: 50
Hue: 0
Color Temperature: Warm 1
Sharpness: 60
Noise Reduction: auto
MPEG Noise Reduction: Off
Dot Noise Reduction: Off
Cinema Drive: auto
Advanced Settings
Black Corrector: off
Adv. Contrast Enhancer: Low
Gamma: 0
Auto Light Limiter: Off
Clear White: off
Live Color: low
White Balance: ** (this is very important)
Detail Enhancer: low
Edge Enhancer: low
Skin Naturaliser: Off
i/p Conservation Prefrence: Quality
**White Balance (settings)
R Gain: 0
G Gain: -4
B Gain: 0
R Bias: -1
G Bias: -2
B Bias: -3
Setting for watching Bluray
Backlight: 2
Picture:max
Max Brightness: 50
Color: 50
Hue: 0
Sharpness: 70
Noise Reduction: off
Cinema Drive: auto
Advanced Settings
Gamma: 0
Clear White: off
Live Color: low
Edge Enhancer: low
R Gain: 0
G Gain: 0
B Gain: 0
R Bias: 0
G Bias: 0
B Bias: 0
Other pic settings are not available for my tv cause it's x-reality not x-reality pro so I guess u can get those from someone who owns that model.
I keep my picture always on FULL mode...it streaches 4:3 SD video from d2h but keep the aspect ratio normal for full hd channels. Also for watching bluray full hd will appear full screen but if any video appears with black bar in top and buttom of the screen(aspect ratio more than 1.78:1) you can select zoom to get full screen picture.
As you're gonna use different hdmi port for tata sky and ps3 you can apply different settings for different hdmi port.
Which 3D glasses you got..
first one
Second one
That's bad. Those are bulky and bad looking also you cant wear them on spectacles.
Why sony you did this with Asian customers.
My new picture setting:-
Scene CINEMA 1
Backlight 3
Picture 95
Brightness 25
Color 50
Hue O
ColorTemp WARM2
Sharpness 50
Noise Red OFF
MPEG Noise OFF
Dot Noise OFF
Reality Crea OFF
Video Area OFF
Resolution OFF
Noise Filt OFF
Smooth Grad OFF
Motionflow STD.
Cinema Mode AUTO 1
Black Corrector OFF
Adv. Contrast OFF
Gamma DEFAULT
Clear White OFF
Live Color OFF
G GAIN: 0
B GAIN: 0
R BIAS: 0
G BIAS: 0
B BIAS: 0
Detail Enhancer OFF
Egde Enhancer OFF
Eco OFF
Wide Mode FULL
Auto Wide OFF
4:3 Default OFF
Screen Position N/A
Vertical Size N/A
aks316 thanks for the tip of THX optimizer..I've tried it on my set..change gamma to -1 to achieve perfect black level as per specification. Seriously black levels are mind blowing in this sony leds.
