Hi Experts,
I do have a good cassette collection which I do not want to discard.
Recently I purchased a Sony home theater system. (Model No. DAV-DZ390K)
Now kindly advise how I can connect a cassette player to this system.
I do not want to spend much on the cassette player.
So the product which I have in my mind is TC-30 of Ahuja.
All the required specs of the above product are given in the below link.
http://www.ahujaradios.com/Literature/TC-30_OM.pdf
The required specs of my Sony HTS are given below.
Power Output - Front (RMS) 144W x 2
Power Output - Center (RMS) 144W
Power Output - Surround (RMS) 144W x 2
Power Output - Subwoofer (RMS) 280W
Power Output - Total (RMS at 10% THD) 1000W
AMPLIFIER
S-Master Yes
Audio Line IN/OUT (Analogue) 1 /
Audio Line IN/OUT (Optical) 1
Audio Line IN/OUT (Coaxial) 1
Audio Input (Front, mini) 1
Video Signal IN/OUT (Composite) / 1
Video Signal IN/OUT (Component) / 1
Video Signal OUT (HDMI) Yes (1080p)
USB 1
Headphone Jack (3.5mm / 6.3 mm) 3.5 mm
Mic Input Jack (3.5mm / 6.3 mm) 1
D.C.A.C (Auto Calibration) Yes
Bass Boost Function (Dynamic Bass on RM) Yes
Night Mode (Normal/Plus) Yes
Movie/Music Mode Yes
Portable Audio Enhancer Yes
Dolby Pro Logic/Dolby Pro Logic II / Yes
Dolby Digital Yes
I HAVE THE FOLLOWING CONCERNS.
1. Will this analog player be compatible with the Sonys s-master digital amplifier?
2. What type of accessories/cables I require to connect these two products?
3. The manual says TC-30 can be connected to any amplifier which is having AUX input sensitivity less than or equal to 250mV. (Pls. have a look of the user manual whose link I have pasted above.)
4. If these two are not compatible, kindly suggest some other product.
I request you all, to give some suggestions, guidance at your earliest.
Thanking you,
Sami
AMPLIFIER
S-Master Yes
USB 1
Dolby Digital Yes
Thanking you,
Sami
