hardcore_gamer99 Well-Known Member Joined Mar 3, 2024 Messages 948 Points 63 Location india Aug 25, 2024 #1 Netflix showing black bars on top bottom. I tried wide screen but it says feature unavailable why so
A altair21 Active Member Joined Jun 5, 2023 Messages 139 Points 28 Location India Aug 25, 2024 #2 black bars are fine, that just means OLED has turned off the LEDs in those areas,
W whiskymusic Member Joined Apr 9, 2022 Messages 94 Points 18 Location Kolkata Aug 31, 2024 #3 Check 8% gray screen & see if you notice vertical bandings. Run panel refresh if it's been long while. One good suggestion I've read is to keep screen away from direct sunlight & supply switch off when not in use.
hardcore_gamer99 Well-Known Member Joined Mar 3, 2024 Messages 948 Points 63 Location india Aug 31, 2024 #4 altair21 said: black bars are fine, that just means OLED has turned off the LEDs in those areas, Click to expand... only amazon prime runs in full screen all other streaming apps mostly show black bars on top and bottom. no burn in effect?
A altair21 Active Member Joined Jun 5, 2023 Messages 139 Points 28 Location India Sep 1, 2024 #5 hardcore_gamer99 said: only amazon prime runs in full screen all other streaming apps mostly show black bars on top and bottom. no burn in effect? Click to expand... yep, no burn in for black bars but do run a panel refresh cycle tho
