Sound "crackles" when volume is increased and decreased
CTC..Carbon Tetra Chloride...it is available at a chemist
This stuff used to be (is?) used as dry-cleaning fluid, I think?
It is not much fun to inhale: use in a well ventilated place.
greenhorn said:
If you haven't already figured it out, a variable resistor should be a two terminal device, and the resistance between the two pins would be variable.
A potentiometer is a three terminal device. with a fixed resistance between two pins, and the third pin somewhere in between, depending on the positition of the slider/wiper.
You can make a variable resistor out of a pot by just not using the third terminal
Yes, I got as far as that, but without much understanding as yet. I've barely started on the site I mentioned above...
No thanks button on your post, so Thanks! :)
