My bad, SL6Y has DTS:X and SL8YG with Atmos + DTS:X.SL6Y doesnt have atmos capabilities. Rear speakers will bring 5.1 effects
I would recommend getting a pair of active speakers. JBL nano k4 is a good option. Well within Ur budget. They are quite bassy enough for a medium to small room but If u feel the need for more bass add extra subwoofer later on
My living space is not perfect square it stretches into dinning space, distance between Soundbar and sofa is 10ft. I feel the sound effects will be more pronounced when you have reflections from left and right walls which is kind of missing in my space. When audition it in closed HT room at shop it was perfect as the room is enclosed and brings out perfect sense of surround effects. In our actual living rooms you will see it will reduce by 20-30%. I guess this will be the case with any soundbar out their in the market today. Does that mean it’s bad, the answer is “no”, it really brings good movie experience overall.
With current discount on LG Sound Bar SL6Y it makes really good VFM below 20k as it provides you the option to expand with rear wireless speakers which can be added later too with decent Dolby atmos capability.
Any thought on Sony HT-S350, JBL 2.1 DB & Polk Audio Signa S2 ?
Those speakers have RCA input and they are quite good if you want good audio in budgetProfessional monitor speakers?? How do i connect it with TV bt, aux, rca?
Is it ideally better than hdmi arc & optical input on soundbars? I was totally focusing on soundbars
Right now looking among Sony HT-S350, JBL 2.1 DB & Yamaha YAS-109 Max looking under 20k.
Soundbars are the worst at delivering dialogue atleast the budget onesThose speakers have RCA input and they are quite good if you want good audio in budget
Soundbars won't get you the same clarity in the mids and always muddy bass. Watch few reviews online or YouTube you'll know they are worth it
Samsung HW-T550Which ones you consider to be better / best at delivering dialogues
Any views on Yamaha YAS-109 (No Sub) & Samsung HW-R650 Soundbar?Samsung HW-T550
Yamaha YAS-207
I have the YAS-Any views on Yamaha YAS-109 (No Sub)
I have the YAS-109107 and it does the job for when I just need a bit of a volume boost and don't want to have to turn on additional equipment. Voice clarity (esp. in it's clear-voice mode) is good. If you want the low-end rumble you will need a sub. Room size and shape play a part in how it sounds. The virtual surround modes work better reflecting off a surface (ceiling etc.) as compared to when it is coming at you straight on. Like all soundbars there are limits to what it can do, so no comparison with a 2.1/5.1/7.1 etc. system.
Listen to both at the same place or look at some measured graphs if they exists. Subjective opinions are salty.Thanks for your comment
I had one small query regarding frequency response (62 Hz to 23 kHz), does it affect in anyway? As others normally has it from 40 to 50hz?
