Tuhin Lavania
I think the prices are fine. The A52+ retails for 3.26L and Emotiva prices are okay too.
Looks like a nifty, little thing, the Schiit Loki:I think the primary reason was cost and second was one less thing to deal with.
After this decision was made, the "pure signal" spin was invented for marketing/justification.
Raghu
Most of the time stereo amps used motorized volume pot which is not digital way.So input signal is not changed or processed..
AVR is works differently-
Analog input to AVR but volume control is digital?
Hi All, Just plugged in CD player to my AVR via analog inputs to use my CD player's DAC. However, the volume control on all AVRs' is in the digital domain... ...so am I right in thinking doesn't matter what people do with the outboard DAC that costs £200 or £2000 when it's put in to the...www.avforums.com
Dear Fm’s
During my entire HT journey I have never given interest to stereo but after purchasing 4500 it really got me addicted especially in pure direct mode.But recently it sounds very bad mainly due to the reason the bass is so muddy and flat. There is no thump or punch at all in the z3. I would like your opinions on what can be the issue. There are 3 possibilities and that the problem is with avr or the speakers.The 3rd possibility is which I highly doubt is the reason and it’s after I installed 65 inch c9. As you can see in the image below when I had a 43 inch tv the speakers were not so wide apart and also had enough room around them. For installing the c9 I had to move both the LR 2-3 inches apart. Now they are slightly wider but as you can see there is no breathing space in the sides as they are almost kissing the c9. Your thoughts on the subject please
I don’t use any inverter/ups for my system. Just connected them to a vertex servo stabilizerWhat inverter/ups you are using?
Marantz is among the few mainstream amplifiers that retains tone controls, and a way to defeat them by the 'pure direct' switch. The PM8006 even has a midrange control, possibly the only model with the feature. This was one of the reasons for my purchase. It does help me with my listing room's bassy character and can tweak a lot of poor recordings.Very true. One of the relatively recent integrated amps which looks comprehensive with controls though on the expensive side is the Parasound Hint 6. It has the tone controls with dedicated subwoofer connection with a crossover knob which truly helps people with small bookshelf fronts looking for good 2.1 music.
I have not fiddled with the midrange. I generally use to tone down the bass when it starts shaking the house and occasionally accentuate the treble as my Wharfedale speakers have marked HF roll off. My QA speakers are much better and require less tweaking. I'm planning to change my speakers to better ones and expect much less tweaking. PM8006 is a transparent amplifier and bad recordings sound bad, come what may.It's a good thing to always have tone controls for poor recordings imho.
Does the midrange knob on the Marantz accentuate vocals clearly ?
check if crossover is set to LFE+MainI observed that in pure direct mode subwoofer doesn’t work, only L/R works. When we switch to stereo mode, subwoofer becomes active
That's the way all AVRs are designed to work. With Yamaha avr, SW used to work in Straight Mode.I observed that in pure direct mode subwoofer doesn’t work, only L/R works. When we switch to stereo mode, subwoofer becomes active
Thanks for information. I used only Denon and Maranzt.That's the way all AVRs are designed to work. With Yamaha avr, SW used to work in Straight Mode.
In Denon 4500 u can make the sub work in pure direct. There is an additional 2ch settings and there u need to make some changes. Through shield if I play any 2.0 tracks sub works in pure direct but while I play some tracks using airplay the sub doesn’t workI observed that in pure direct mode subwoofer doesn’t work, only L/R works. When we switch to stereo mode, subwoofer becomes active
Thanks for information, bdw excellent and high end set upIn Denon 4500 u can make the sub work in pure direct. There is an additional 2ch settings and there u need to make some changes. Through shield if I play any 2.0 tracks sub works in pure direct but while I play some tracks using airplay the sub doesn’t work
