Is 44.1kHz/24-Bit the sample rate/resolution of the stream obtained after decoding? Was it also the rate/resolution of the original source from which the mp3 was encoded?Have you noticed Volumio boldly declares a track "MP3, 44.1Khz, 24-bit"?
Something ain't right here.
Raghu
No ideaIs 44.1kHz/24-Bit the sample rate/resolution of the stream obtained after decoding? Was it also the rate/resolution of the original source from which the mp3 was encoded?
With regards,
Sandeep Sasi
It is not an underlying feature of the MPD under Volumio. It cannot read the cue playlist and will be interpreted as a single flac file.I have a few albums that are indexed by cue files.
The FLAC is the entire album.
It seems looks like Volumio can index these but cannot play tracks individually.
Any tips/tricks for this?
Raghu
Yeah. That's what I have to do.It is not an underlying feature of the MPD under Volumio. It cannot read the cue playlist and will be interpreted as a single flac file.
You have to output to flac/wav on PC and rewrite to the hard disk and update the library
If you access files NAS way, its possible to specify the source path where audio is stored. But USB is different and I really doubt if we can instruct volumio to update the library from a specific source folder.Can Volumio on Digione be configured to index only a partition on an external HDD?
Currently, the HDD used has movies stored on them too (and other stuff like docs, photos).
The OS indexes the audio portion of these movie files, which is a waste.
If selective indexing is possible, I can still use my existing HDD.
Otherwise, may have to get a new one and keep 'em separated.
Raghu
IsCan Volumio on Digione be configured to index only a partition on an external HDD?
Raghu
Raghu
If the DAC has only COAX input (and it is not already occupied by some other source) get the Digione or Digione Sig.I was thinking between the USB version (allo usbridge signature) v/s the coax version (allo digione signature).
My dac does not have usb input. It only has optical and coaxial. So i had a doubt. suppose if i purchase the usbridge signature version, and convert the usb signal to optical/coax using a convertor which i already have i.e. topping d10, then would it reduce the sound quality? OR, it would be better if i purchase digione signature (coax version) and output it directly to the dac. which one would be better sounding?
Go for USB version only if DSD is important to you; but then you'll need a new DAC.
Raghu
When you compared the two modes of DAC were they fed from same source.Thanks. there is one more point i observed in my dac. it has 2 inputs, one is optical-toslink and other is coax.
when i play via optical it sounds warm and pleasant.
when i play via coax, it sounds less warm, slightly more detailed. less engaging sometimes compared to optical.
now i am not sure if this is the property of coax, or my dac has different implementations of optical and coax.
so the problem is, digione signature has ONLY COAX and not optical. so my worry is if i use coax then it will sound less warm compared to optical.
Usbbridgs signature has the option of adding the digione signature board for coax output. There is a review of the usbrodge signature by Hans Beekhausyen on youtube. Worth a watchI was thinking between the USB version (allo usbridge signature) v/s the coax version (allo digione signature).
Raghu
Hmmm ...Yes, it was the same source. it was something like this.
RPI usb output --> Topping D10 ---> optical out to DAC
RPI usb output --> Topping D10 ---> Coax out to DAC
I had done something similar using other convertors (usb to optical/coax), and found same issue that coax is slightly bright.
Hi Amit,Yes, it was the same source. it was something like this.
Hi Shyam,Hi Amit,
I understand that you have two DACs in your chain Topping S10 and Mini Muse where the former is a USB-SPDIF convertor and later does SPDIF to Analog RCA conversion? Is there a reason why you need to convert USB to SPDIF coax or optical and then again to Analog signal? Can't you directly connect RCA output from Topping D10 to your Yamaha Amp?
Thanks,
Shyam.
