elangoas
Assuming 70% is the 70% of the total reference range, then I'm even more confused on how it will work. In Yamaha RX 371, from -65dbl to -45dbl (I'm refering to reference range), there is no 'significant' change in volume, but the main change starts from -40dbl onwards. It goes till +16dbl. Now given that there is no change in the lower levels, 70% of which range should be considered?
You can consider -65db to -10db as 70% of the volume as your max is +16db...
In my new Onkyo AVR, the volume ranges from 0 to 99 (Max)...In the same way as your AVR, i need to bring the volume to atleast 40 to hear anything..
For stereo, my listening level is around 55 ~ 60... For movies, my listening levels are 60~65..
