Speakers for home theatre
lamborghini
Hello everyone!
I intend to install a 5.1.2 home theatre set up in my den room of 12 by 12 feet.
I have already picked up a ONKYO TX-NR-656 receiver and a pair of Micca M-8C 8 inch 2 way in-ceiling speakers (to be used for the ATMOS effect) from the US and I'm only left with the 5.1 now.
Can someone suggest good satellite speakers that I can use for my room? Looking for wall mounted speakers preferably as don't have too much space for book shelves or towers.
My usage will primarily be for movies and music; 85:15. I will be installing a projector (BenQ W1070) and a 100 inch screen as well.
Thanks in advance!
What is your budget for 5.1 speakers? There are lots available in the satellite category....
If you are on a tight budget, you could look at pre owned stuff available in Hifi Ads or olx....some real good stuff
If you'll be wall-mounting your speakers, here are my picks for limited budget yet good performance.
Fronts : Dali Zensor 1
Surrounds : Sonodyne Genie 1
Center : Mission MXC2 / Wharfedale Diamond 220C
Sub : Taga TS-120 v.2
My budget is about 40-50k tops
@Anubis: Will this fall in my budget? Where can I hear them in Mumbai before buying them?
No those won't fit in that budget. If you want everything at one go in that budget, look at wharfedale dx1se or tannoy tfx 5.1. Better would be to start with a pair of bookshelves plus subwoofer. Add center and surrounds later when budget permits
Sent from my ONEPLUS A3003 using Tapatalk
Fronts : Dali Zensor 1 ~23K or Wharfedale Diamond 220 ~19K
Surrounds : Sonodyne Genie 1 : ~9K
Center : Mission MXC2 ~15.5K / Wharfedale Diamond 220C ~16.5K / Sonodyne Sonus C2501 ~9K
Sub : Taga TS-120 v.2 ~20K
With your budget, you can buy a whole 5.1 package like the Wharfedale DX-1SE or make your own package which is also possible within your budget but I'm not sure if you'll love the combo, although it would be great if you come from computer speakers.
This is not coming in my budget! I heard the Harman Kardon HKTS 30 and quite liked the sound. Any reviews on it?
If you like the sound, go for it.
Also audition the Wharfedale DX-1SE. For audition, call them beforehand : HifiMart, Kolaba, 93223 37331
