square_wave
I dont listen to lossy compression.
Tidal HiFi is what i referred to as a high quality elevator music..
I would urge all to try it side by side with playback of the same CD.
It is surprising to see that so many on this HiFi forum are content with lossy compression.
There are also so many posts where the members are not aware of the HiRes (PCM) format.
I hear you.
All problems associated with PC playback applies to streaming too. High noise floor, Digital sheen riding on the sound are all typical pc playback issues if the playback chain ( pc / streamer and dac ) are not optimized well. It reminds me of the early days of PC playback. Have tried many things. The best that sounded to me was the dual pc configuration with Jplay. Later I tweaked a mac mini like crazy and tried audirvana with locally stored wav / flacs. That sounded very good. But a well made streamer like auralic beat that too. Many a times, I have seen people connecting to tidal using a laptop and just plugging a usb dac in. That may not sound so great.
I spend some time again last weekend doing some comparisons in my system as well as a friend's fully active system. I would still like to stay with my earlier observations. Tidal hifi is 90 percent there if one is using a high quality streamer or a pc optimized for high end playback on a dac designed optimally for such an application. Also, the file at Tidal's end must be good. So many variables are there.
The last ten percent improvement with cd / wav playback I noticed was all about natural ebb and flow of music, lack of digital sheen riding on the music, slightly lower noise floor etc. Surprisingly, I don't find loss in dynamics with tidal. Dynamics loss happens only when you lose data via compression and higher noise floor due to a bad pc. I use an auralic aries. If you guys can give me some examples of albums, I can check and circle back.
For some albums, the cd / wave sounds considerably better while with others, the difference is miniscule. I think it depends on the quality of the file sitting at tidal's end. A good example of a bad quality file at tidal end is "The best of Simon and Garfunkel ". The cd / wav stored locally sounds way better.
My listening is 50 / 50 casual ( music in the house while I work ) and critical ( in the sweet spot ). For casual, tidal works perfectly.
I also think tidal is not fully lossless. Someone in the industry was saying that there is some kind of compression involved. Don't know the specifics though.
Overall, the best solution is a locally stored wave or a cd spinning on a high end transport. I have also noticed that an average level cd player sounds worse than a good quality file streamed from tidal or from local storage.
