Stabilizer for my setup
vinothkumar
Chennai
Hello people,
Just bought SONY 50W800C and I have my SONY STR DN1050 AVR with HD Tatasky STB.. Now I need your help in finding good voltage stabiliser to match all these setup.
Thanks in advance
For your needs 4 amps one sufficient. 6 amps one is more better. Both are come with bigger plug (not with regular plug). 4 amps one you can use with converter.
Hello people,
Thanks in advance
I have 40 Inch Sony LED, 2 Genelec Active monitors, 1 Genelec Subwoofer, Tata Sky, Tplink Dual band router, Google chromecast, for all these i have bought
1 KVA Servo stabilizer, it will be a more expensive than regular one, but i presume you know how good servo stabilizers are !
By the way, 1 fun fact, i was roaming around Phoneix Market city in B'lore, i noticed the bands were using Servo stabilizers back stage :)
I would recommend that you get a good isolation transformer along with a servo stabilizer, especially if you have erratic power supply and your AC's are on the same line. Will help protect your equipment and prolong its life.
Thanks people, I unknowingly bought 3A stabilizer which is vguard crystal plus. Is it Ok or do I need to upgrade it?
U can go for V guard Digi 200 stabiliser which is 6 A otherwise Crystal plus 3 A ,both are good. I'm using it both for past 3 months along with Belkin surge protector, no problem faced till now.
It costs 3300 INR. I checked with the service centre guys they told this will be sufficient for the whole setup. I connected them also. So far working good. Will it cause any damage to the equipments?
I am not exactly understanding between amps and KVA. Can some one analyze? In view of KVA, what is the meaning of 4 amp stabilizer?
Power factor rating of stabilizer is 0.7 or 0.8. 1 KVA=700 or 800 watts.
Assuming 230 volts power supply, maximum 3 or 3.5 amperes load is suitable.
Volts x amperes=watts
