Stabilizer or UPS
dcoolguy
Guwahati
hi,
i need to protect my home theatre setup from voltage fluctuation n surge but confused between Stabilizer and UPS.
My current setup
Sony 40EX720 TV directly to outlet
Denon AVR 1611
JBL Subwoofer
these 2 on Logicstat 2KVA stabilizer
and
Asus Oplay mini
Tatasky+ HD
these 2 on APC 1100VA UPS
Is this the right setup ?
help me.
It depends on what is your requirement.
If TV is connected directly to outlet, then whats the point of using UPS which is connected only to the sources (media player & DTH) ?
If you want some backup of power for watching some stuff on TV during a power cut, then UPS is right for you (TV will also have to be connected via the UPS).
If you want to just protect everything from voltage fluctuations, then a cheaper stabilizer will do.
