Stereo Amplifier For Polk RTi A7
riteshmadhok
I plan to get a pair of Polk RTi A7 tower speakers, I was told these speakers need a powerful amplifier, need to know my options for the amp to drive the RTi A7 towers.
I would suggest not going for Denon. The combination might sound too edgy and bright...
IMHO, the RTi series is probably the only 'decent' sounding one from Polk but it's still on the brighter side. You'd probably do well by combining it with a warmer amp like Marantz. Nad might also be a reasonable match.
What kind of music do you like? What CDP & cables are you going to use?
I dont have much knowledge on the cables or CDP would need advise on that too, I would be listening to 80s Pop, the usual bollywood, Jazz and a easy listening music.
Update - Just picked up a pair of Polk RTi A7 towers yesterday from a FM. Being a novice, I would need help and guidance on building the system. As mentioned I got a Yamaha RX-V467 Receiver and now these speakers. Which Stereo Amp do you recommend, Do I need a DAC? Please help.
