Stereo System under 35k (Convert Car Audio vs Home Use)
dub123
GJ
I read through similar posts, but am torn between two options.
Option A)
Helix Precision 400 Amp (Class A, 4 Channel)
Helix Speaker Set from same series, 2-way component system, 165 mm / 6,5" woofer with stiff paper cone, 25 mm / 1" silk dome tweeter with neodymium magnet, separate crossover with tweeter protection
and additional cost for getting the housing and good SMPS
All these will add up to somewhere close to 35k
Option B)
1) Either some thing from lower end series CA, Sonodyne and comparable BookShelf speakers.
2) I am more interested in getting higher grade system like Marantz even if it means to go used route but general search of hifiad, olx it looks like they do not come up that often.
Usage wise it will be 70 (music) : 30 (movies)
I listen to wide variety from metal to classical, but not much into boom boom. So bass quality is more important and looking for neutral sound.
Please suggest.
