Re: Why Stereo Speakers are better than 5.1 for Music ?
Power rating has no value. If you go into the design of an amplifier circuit (there is a thread somewhere where I have explained this in great technical detail with diagrams and such), a preamp sends the sound signal as direct current. The amplifier adds gain by adding AC power to the DC data and sending the combined power to the speakers. It is here that the design and construction of amps make a huge difference to the sound signature. Even assuming the speakers get the same amount of raw energy, how the speakers sound will vary depending upon how the amplifier is constructed. You can create two amplifiers in the same class with the same power output at the same price category, but they will sound completely different.
When you are adding AC power to a music signal, you are adding a lot of accompanying noise. How this noise is managed is the direct result of the amplifier design.
I never said an AVR is inferior in any way. Just that they are meant for a different job. Even if you design the amplifier in a way identical to the 2 channel amp, since there are so many other circuits that can generate noise, a bit of noise will always creep in. If you want avoid this, the amount and extent of shielding needed will make the AVR inviable. Most manufacturers of AVRs thus optimise for movies and leave it at that.
I have to go into a whole new area of DAC design. But let me say this. Though you are correct in saying that a digital signal is identical once it leaves the CD, that is not the end of the story. A external DAC will have to contend with a fixed signal. If it finds an error, all it can do is approximate the data and fill in the gaps, or skip that data area completely. In a CD player, if designed properly, the DAC can request the the drive to re-read the data. This can be done multiple times till it gets the data it thinks is best from, say, 4 reads.
There is whole lot of advantages in a DAC conversion as near to the source as possible.
In addition, as digital transmission in Audio/Video does not have feedback, there is nothing the receiver can do if there is a signal loss during transmission. Again the receiver has to approximate or just amplify and send the erroneous data to you. If you are using a optical cable, a 90 degree turn could easily distort the signal as the light signals bounce off the internal walls. There are similar issues with coaxial digital cables as is there with HDMI. As the length of HDMI increases, there is appreciable signal loss. In essence, there is no guarantee that the receiving end's data is 100% equivalent to that of the sending end.
Take your pick.
We are not comparing a stereo amp costing 30k with an AVR costing 30k. If that would have been the case, the amp would win hands down. My point of comparison is the power rating. If two amplifiers have the same power rating, specified over the same frequency range and impedance and with same THD figures, they would sound the same. One can be a dedicated amp and the other can be an AVR. This assumes that the signal is not being modified by doing any processing etc. All this is, of course, in analog domain.
The contention is whether AVRs are inherently inferior to dedicated amps. An AVR with same components as that of the dedicated amp will sound the same. It might be more costly than the amp but price is not the contention here.
Regarding DVD players vs CD players, my opinion is that if you are not doing any processing on the data from the moment it is read till it reaches the digital out, it should sound the same. That is the whole point of having digital data. Please note that I am talking about digital out and pristine CDs. A better DAC with excellent jitter correction will have better sound but that comes after the digital out.
Take your pick.
