Stero setup under 20k(max 22k )
funskar
Bihar-(India)
Hello ..
Need a stereo setup with good bass effect under 20k max 22k.
Listen to music n watch movies when have 3-4hr free time..
Recently 20days before purchased yamaha yht 196 bt returned it due to problems n got full refund+shipping charges:ohyeah:
2 spkrs + amp
Will connect it to my pc via xonar dx
Hello ..
If you are planning to buy brand new amplifiers, then you can consider Norge 2060/1000/2000 which will cost you about 10 ~ 12K...
For brand new BS speakers consider Norge Nano, Sonodyne Sonus 1501 & Cambridge Audio S 30... Approx 10 ~ 12 K....
+1 to this recommendation....covered the best you can get at the price!
Gone through hfv other threads n avmax ..
there is one pioneer sp fs52 floorstanding .
will it be good ..
avmax - 15k
avenuesound - 23k ..
Pioneer SP-FS52
Then suggest a good amp for it..
Otherwise I m going to buy a cheapo 2k 2.1 spkrs n save more money till jan 2014 or till sonodyne 26% off offer n then will buy sia 320+2605 v3..
There are many who suggested some combos for your budget.... Pick the one that suits you...
Yeah ..
But now thinking different:indifferent14:
Thinking of getting floorstandings spkrs with amp under 30k..
And later on add center/rear/subs n a receiver for 5.1 setup
how is pioneer SP-FS52.
What should i do?
wait to buy at once/temporary cheap spkrs or buy fs now
A lot of us can suggest a good suitable system within your budget but you need to go and audition some models and brands....you need to see what appeals to you and your budget....so go ahead and take some demos at your nearest Home Theatre or Hi Fi Dealer and provide us some more options to give you a possible solution.....there are some threads on HFV which you can search and find some answers....
From my experience....I don't think the Pioneer model suggested by you is good value for money and performance....there can be others who have a different opinion...it all matters what appeals to you....
Just sorted out those pioneer one's from reviews, also sawd take calssic ..
I can't audition any hifi systems n speakers here..
There no dealers or showroom's who sell these or know abt these..
Just sony samshit pana fags:ohyeah:
If you want a reasonably good setup with FS speakers at low budget, then Sonodyne is the best VFM. I'll suggest not to buy any entry level imported FS. Also, keep an eye on `For Sale' section for a used amp.
whatever you set your mind, and ears, on, be sure to audition them thoroughly before buying. give them a good listening in the store. if possible, move the speakers a bit.. turn them towards you, sit back, listen. if you have an audio cd with songs you are very familiar with, take those and make them play it.
hope this helps.
