Posting a picture of the connector.
'Hi' to everybody. This is my first post here.
Congratulations 'captrajesh' for the nice aquisition.
Actually this connector has nothing to do with Tannoy in a proprietary sense. These were just standard connectors of the valve era, and they were used mostly in the modular-designed pro-products of those days' like RTR decks, pre-amps, power-amps, mixers etc. to feed power/signal and the like. I have seen them in old AKAI & Ferrograph valve-RTR decks. So the best bet to find one will be something in that line's junkyard.
In the mean time till a connector is acquired, one can just solder 4 wires to the backside of the available socket counterpart, and terminate them to a suitable modern connector.
And yes, pls do not discard the old xovers, I mean the original ones. They can be repaired. Also these speakers will sound better with valve amps. This has been already mentioned earlier by Rajiv, but there was some disagreement there from other members. It is true that one can always experiment, but the fact also is that these are of 0.2 Qts value, and will definitely benefit from a bit of more current loading, particularly when housed in big enclosures, as is the case here.
The T/S thing happened in 1971, by which time these drivers were already in tremendous use. So these guys knew the inter-reactions well. May be they did not question the fall-of-the-apple, but they were already making good wines from them and enjoying also.:lol:
So you also enjoy.
Aditya
