Mayank Shah
Looking for a 4 meter sub woofer cable. Which would be the best VFM cable under or around 3k? Can stretch max to 5k if it's worth it. Thanks
Amazon Basics or Bluerigger on Amazon. They are the best VFM cables.Looking for a 4 meter sub woofer cable. Which would be the best VFM cable under or around 3k? Can stretch max to 5k if it's worth it. Thanks
Any reason for staying away from bluerigger ?Stay away from Bluerigger. I have 2 15ft cables and i dont use them anymore. Got Monoprice and they are excellent.
Lots of interference. I had my both subs connected through it and even if the cable is touched, the subs gave out a lot of interferece. I was pretty sure it was not a ground problem. Switched to Monoprice and the issue is gone.Any reason for staying away from bluerigger ?
Yes subwoofer cables needs good shielding thats very important.Lots of interference. I had my both subs connected through it and even if the cable is touched, the subs gave out a lot of interferece. I was pretty sure it was not a ground problem. Switched to Monoprice and the issue is gone.
Otherwise the bluerigger is fine.
I plan to sell my 2 x AudioQuest Black Lab subwoofer cables, they are 2 meters in length. Upgraded to Nordost so don't need them.Looking for a 4 meter sub woofer cable. Which would be the best VFM cable under or around 3k? Can stretch max to 5k if it's worth it. Thanks
If (no) shielding is a problem, you will get noise all the time. In this case, improper crimping/soldering of the RCA caps may be the problem.Lots of interference. I had my both subs connected through it and even if the cable is touched, the subs gave out a lot of interferece. I was pretty sure it was not a ground problem. Switched to Monoprice and the issue is gone.
Have a Chord C-line Subwoofer cable if you are interested..Looking for a 4 meter sub woofer cable. Which would be the best VFM cable under or around 3k? Can stretch max to 5k if it's worth it. Thanks
