BTW, what does the YPAO mic do? only measure the distance and set the speaker volume and distance levels..right? Or is there anything else that the YPAO help in? I have measured it manually and set up since I have lost the mic.
Using the Yamaha RX-V475. I have ordered the Bluerigger cable and it should be arriving soon. I mainly got this for watching music videos on youtube and movies on Netflix.
Will connecting a Y cable (Single Pin Sub out from Amp to Dual Pin Sub in (Left and Right) improve the bass and increase the volume? Even that cable is on its way.
Have not tried with the Y cable. LFE should work , Netflix should be fine (I mentioned YouTube content). Try with the new bluerigger cable , my sub output improved .
Also try to play around with cross over values.
