iiirshad
M planning to buy it for only audio listinng purpose.
So want you genius people abt it
replyThe fact of the matter is that every one hears different kinds of music......some like loud levels of bass which vibrates the floors while others like a normal presence of bass.....each one has their own expectation and preferences......
It is recommended to hear / audition yourself with your kind of music so that will help as a reference to decide. Personally, I use a BIC America PL 200 and it serves quite well for music and movies......
Sealed subs go well for music. Swans or Warfdale should be good if your budget is limited. Else can move upto SVSreply
is there any specific model of sub did compony make for only listening music ?
Is it worth the money?I recently saw Rel T9 and sumiko S9 on Amazon India. Don't if they are still there. Both of these are damn good for music. And they are designed to be corrected differently to the system. So please read the review thoroughly of either of these subs before you buy. Or you might repent later, as these two subs are very different on how they need to be connected. All the best
James audio m213 if budget and space are not a criteria.Hi
If you have already spent that kind of money for a sub then sky is the limit, you should look at bigger subs (18 inch drivers) which can really go low and provide the level of performance you are expecting......possibly hooking 2 12 inch subs may help......
https://www.themasterswitch.com/best-subwoofers
I was an active DJ in the past and so is aware of what an 18 inch Bass Bin can do...there are various designs of such Bins compact and flare type which perform differently......anyways....for now, for a home purpose...i am quite satisfied with the BIC America PL 200 which is value for money and works / blends well with the other speakers hooked to the system.
already had Beolab 2. Of B&O.
4.75 L.Per piece. Had 3 unit.
Using as only listening music. Very depth n tight bass.
But not satisfy.
Please share some pics if you can.. You have some very good components & have done room treatment too..
Here are a couple of pictures of my home theater. The rear speakers are not ideally positioned - they need to be raised/angled by half a foot or so. I have decided to go with Rythmik LVX12 for the subwoofer. I should have it in a couple of weeks (purchasing it from ProSonics - Santosh has been super helpful).
Great looking room..Here are a couple of pictures of my home theater. The rear speakers are not ideally positioned - they need to be raised/angled by half a foot or so. I have decided to go with Rythmik LVX12 for the subwoofer. I should have it in a couple of weeks (purchasing it from ProSonics - Santosh has been super helpful).
For how much did you get the lvx12 subwoofer?
