The Baron Groog
Ame, put simply: YES
If you can filter the bass from your existing speakers they will play the frequencies they are producing better, with greater clarity and detail.
Think of your speaker as a pond and the sounds it produces as ripples. Split "music" into Bass, Mid and Trebble. If you throw a small pebble(trebble) in along with a brick(Mid) and a breezeblock(bass) the ripple from the breezeblock contains the most energy and will cause the biggest ripple-easily washing out the smaller ripples from the brick and pebble. If you throw in just the brick and the pebble you will have two more distinct ripples.
All this is assuming you buy a quality sub-woofer and cross things over properly, a phase shift function on the sub can help remove cancellations and allow you to integrate it properly.
In reality the true "SQ" of the system is irrelavent-provided you enjoy what you listen to!
