Deblin
Hi fellow members,
I am now planning to add a subwoofer to my 3.0 system. Budget is around 90k to 1 lakh range. My room size is 26*11*10, but my listening area is across the breadth. So my sitting position is around 10 feet from my speakers with my sofa against the wall. The subwoofer will complement my audio vector QR1 bookshelf speakers. I use my system equally for movies and music.
Since I am staying in Jamshedpur, I don't have option to audition subs, especially under current situation. Hence my only source of information is going through multiple forums and feedback and information from you guys.
Based on my research I have shortlisted LVX12/FVX12 from rythmik and svs pb2000 pro.
Lvx and fvx is pretty same just difference in cone material. So does a metal cone (FVX12) justifies premium of 9k over paper cone (LVX12) by sounding better?
Also, how does svs pb2000 pro compares to rythmik, given my situation?
Rythmik fvx 15hp is additional 25 k. Do you think that I should even consider it, given my room dimension and sitting position or it would be an overkill?
My current set up is without subwoofers. So this would be my first subwoofer.
Thank you very much for your time.
