bhvm
Hello Friends,
This is with respect to my Creative inspire 2.1 2400.
https://www.cnet.com/products/creat...2-1-channel-21-watt-total-black-series/specs/
It has been with me for some 13 or so years. Really love it. Of late the subwoofer has started a little rattle with bass notes. Firstly, I thought either the driver is bottoming out or Voice coil is rubbing somewhere, So I took the woofer out and tested it in Free air. Negative- the old woofer is still fine. Does not bottom. Surrounds are fine. Spiders are not torn. Tinsel leads are not rubbing anywhere.
So that traces the rattling to the enclosure. Next, I put a sock in the port. That reduced rattle a little. But only so much. So, anyone has any creative ideas on how to trace what is exactly rattling?
I did a physical inspection of Amplifier board. Bigger components like caps etc seem fine and are not loose. I am almost thinking to fabricate a new enclosure around this amp, upgrade to 10 inch sealed woofer and call it a day.
Good day, Folks!
Good day, Folks!
