Kairos?Forgot this Photo in above post.
RightKairos?
Brilliant!!!Right
One more coming to BengaluruRight
YesOne more coming to Bengaluru
Yes. Its Sealed.Bhai, This is sealed version is it ?
I second this , while trying some prototyping I swapped couple of Mundorf (regular white ones) with some industry caps of the same value and honeslty it sounded the same. Again it totally depends on where in our circuit do we have those caps so that their goodness won't reach the driver. For anextreme example if we connect a 2 uf cap in series with a subwoofer, whether its of mundorf silver oil or cheap noname stuff it won't make any difference as the sub simply won't have any response in the place where the capacitors brilliance lies. So many variables here. Sometimes they make sense. Most of the time not.It's all about preference and affordability. Even a bipolar electrolytic will do if on a budget I have used Epcos motor and pump capacitors with good success.
Around 23.13 IST according to Dr. James O'Donoghuetoday is winter solstice !!
please dont forget to see the night sky ( even with the naked eye ) for the great conjunction of Jupiter and Saturn on the day of the winter Solstice !
Next one like this will be in March 2080 - after we are gone.
have a good day all !
Amazing work Sadik bhai. Now you are a true professional when it comes to DIY. This is now encouraging me to build a speaker.Forgot this Photo in above post.
Superb build. What would be the final color of this enclosure.
This is Final ColorSuperb build. What would be the final color of this enclosure.
Thank YouAs always,another fantastic project!
Thank Youvery nice color scheme ...congratulations !
Awesome build sadik.. As always, your attention to detail is exceptional.
