work safe..
in the race against time be mindful of safety..
woodworking requires working with sharp and sometimes rotary tools.. and i want you to be wary of hazards.
Thank you for your concern Bro. I am very much aware of power tools specially the rotary. Safety will always be first concern.
On Top there is another 18 mm Baffle on which the drivers will be flush mounted which can even hide this error but i don't want to make compromise. And regarding to screw mounting there is enough thickness left for the screws to gain proper strength.i must appreciate your attention to detail. The way the rear has been miter-cut will ensure no unecessary back pressure on the woofer. many DIYers miss this detail. However most would leave a some part of the rear un-mitered so as to allow the screws to get a good grip.
if its not a trade secret, how were you planning the mount the screws?
[The flush is 6 mm deep in 18 mm mdf so we have 12 mm left on top baffle in below baffle where the screw hole will be drilled will have thickness of about another 12 mm (after chamfer) so the total thickness for screw mounting will be approx 24 mm which is more than enough
