Iam looking for a subwoofer in and around 50 to 55k budget, currently using HTS12 and wanted to replace, I place HTS 12 is boomy even after the calibration.
Klipsch sw120 is best option in your budget. But audition it before going to purchase.
In classified svspb1000 is for sale for 45k check it. Productcafe is 9yrs
Or Do you havd carpet on your room. If not buy a carpet then again check the sub.
Or
Use the current sub for some time and
increase your budget go for Ascendo,Svspb1000 pro or klipscb Rp1200. Its one time investment.
Close the port of your sub with a pillow or cushion temporarily. Make it sealed and then check. If it works get some mattress foam and close the port permanently.
