Suggest Best 5.1 speakers budget 4k max
prakashr85
chennai
Hi friends suggest me best 5.1 speaker in the range of 4k. It should be available in chennai or else available online. Thanks in advance. I am considering edifier m3500.
Artis,F&D, Intex are some other companies that can be considered.
Even philips and sony has some some models.
A friend of mine recently bought a Videcon 5.1 for around 4k. It sounds bloody superb for the price. Subwoofer goes very low, sounds tight and not at all boomy. The satellites are quite good too but I don't know the model number. Just go to nearby electronic store and audition their best available system, you might be pleasantly surprised.
does sony sa id7000 sound good please reply
@ashokd4ever what you are doing is not done.You are stealing the thread.If you have query open your own thread.Makes no sense taking the lights off OP.
And i seen you doing this in another thread too. Anyways you will learn.We all make these mistakes first time.Cheers and welcome to HIFIVISION :)
The Sony speakers you are referring to are passive 5 speakers with one active woofer. The woofer is a bit boomy and about the quality of the speakers,there are no mids.Also it depends on the source you use to drive the speakers.Someone was testing them at the local computer shop and it felt bad with Lg DVD player he was using. Still at 5.5K price point i had look somewhere.
To the OP.my apologies to deviate from the thread in answering the query of ashokd4ever.
At your budget the best bet if you are bass loving would be F&D 5.1 get it from
F&D 5.1 home theater speakers Free Shipping + Bill+ wty | eBay
And if you are into overall good sound with decent highs ,mids and very okishh lows then go for PHILIPS DSP4000U @ 4K from here
PHILIPS DSP4000U HOME THEATER SPEAKERS 5.1 4000W PMPO | eBay
